Displays password policy information for all users on the switch.
N/A.
To view the password management information, you must have administrator privileges.
The following command displays the password management parameters configured for each account on the switch:
# show accounts password-policy
Accounts global configuration(applied to new accounts on creation)
Password Max. age : None
Password Min. age : None
Password Min. Different Chars : 0
Password History limit : None
Password Min. length : None
Password Character Validation : Disabled
Accts. lockout on login failures: Disabled
Lockout time period : Until Cleared
Username match : Permit
Repeated character : Permit
Long sequence : Permit
User Name Expiry Max. Expiry Min. Min. Min. Hist Lockout Lockout Flags
Date Age Date age len diff Limit Time Time
(Max) (Min) char Config Remain
admin None None None 0 None U - ------
user None None None 0 None U - ------
a1 None None None 0 3 U - ------
a2 None None None 0 90d U - ---rsu
a3 None None None 0 180d U - ------
Hist Limit: Limit is number of passwords (1-10) or duration in days (d).
Lockout Time Config: (U) Account is locked until cleared via 'clear account <name> lockout'.
Flags: (C) Password character validation enabled, (L) Account locked out,
(l) Account lockout on login failures enabled, (r) Repeated characters not permitted,
(s) Long sequences not permitted, (u) Username match not permitted.
Minimum different characters for changed password and minimum lifespan for passwords information was added in ExtremeXOS 30.7.
Username match, repeated character, and long sequence information was added in version 33.1.1.
